I'm going to stiffen the shocks halfway and try it. I know when I first installed them, I adjusted them full-hard and it was way too much.Also, you might try stiffening the setting of the shocks. It sounds like they aren't damping the movement of the vehicle.
Looking at your bump stops its either of the above. Too long of a shock or not enough damping on the shocks.
I suspect, without even pulling the boots down, that you may be right.X2. Slide those boots down. I suspect the shocks are too long for your lift and are bottoming out before your bump stops. At ride height, the length of exposed shaft MUST exceed the length from the pad on the lower spring perch to the bottom of the steel cup in which the bump stop foam piece sits (ignore the foam). Do you have the part numbers for the shocks you bought?
I've owned many different cars and a few 4WD trucks, but never anything with the ratio of so much unsprung weight versus the weight of the entire vehicle. It may be that my (wife's) expectations are overly optimistic....I drove a 2002 Pathfinder, Lexus, Tundra and other 4x4 with independent front axles and those SUV or so call 4x4 are much smoother ride. JEEP WITH LIVE AXLES always drives much worst . You feel all the bumps in the road. This is generally how these cars works. Airing down to 15psi on all tires will help on dirt roads and soften up the ride but is considered not the solution for a more comfortable ride. Since it will impact the safety of the car driving on highway speeds on surface roads. It dangerous to drive on low psi.
What other cars did you drive before buying the Jeep?
Some folks go down and trade her in, but wives aren't bringing much these days . Too many new models on the market.
Are those 10x better than the Rancho 5000x? I’m curiousIt does sound like you are blowing through the stroke
Get the tires at 26 psi
Consider new 50000x shocks
It will be a lot better .
With better headlights!Some folks go down and trade her in, but wives aren't bringing much these days . Too many new models on the market.
Also don't overlook your control arm bushings they can really contribute to overall instability.It does sound like you are blowing through the stroke
Yep. Go big . 50,000.Are those 10x better than the Rancho 5000x? I’m curious![]()
Yes, so those shocks require about 1.5” of bumpstop extension. Exact amount would be determined by actually cycling the axle and checking out when they bottom out.I suspect, without even pulling the boots down, that you may be right.
The part numbers are RS999241 (rear) and RS999239 (front).
According to the Rancho website and the Rancho guy I emailed, these are supposed to be good for a 2.5" lift. I have a 2" lift. (Installed spring heights are 10" rear and 14" front.)
I have load range C tires.
I will try reducing the pressure....
I would not characterize my ride as "harsh" or "washboard" in nature. It's actually rather smooth. Except for when the pavement has long dips or swales in it, the side-to-side rock & roll starts.
That could be caused by several factors. 1st would be excessive rebound damping. on the shocks not allowing the shock to extend quickly enough. Another possible factor would be too stiff of a sway bar. A softer sway bar would allow the wheels to travel more independently and would reduce the body jerk from hitting a depression. The trade-off would be increased body roll on turns and an overall less “planted” feeling.I'll try to better describe the issue I'm having....
Let's say you are driving down a road at 30 MPH, and encounter a depression in the road. The right side of the pavement becomes lower by two or three inches for a distance of 3 feet, and then it rises again Only one tire on the right side is within the depression at any given time. For that tire to fall into the depression, the shock absorber must EXTEND. Hopefully the rest of the suspension will work together to keep the rest of the Jeep in its previous level attitude.
What I'm saying, though, is when my right front tire falls into that depression, the whole Jeep leans to the right and I hit my head on the side window. Then the front tire emerges from the depression, the whole Jeep becomes level again and my wife hits her head on her side window. Then the right rear tire goes into the depression, and all this head-hitting happens again.
I would assume that the shock absorber and the anti-sway bar should prevent most of this head-knocking. Right??
My current assumption is that I have the shock absorbers set way too soft.
(The head-knocking was for illustrative and dramatization purposes only. No side windows were harmed.)
