- Joined
- Apr 19, 2016
- Messages
- 172
ok so i have in the past few years replaced the radiator when it started leaking, and the water pump when it failed. i replaced hoses and flushed the system each time. over the past 2-3 months i've been trying to track a coolant leak and having no luck. it will run fine and not leak as far as i can tell from coolant level for a few weeks then out of nowhere im out of coolant or it will overheat horrendously out of nowhere. the past two times it hasnt blown steam or had the white exhaust clouds of doom but when it cools enough to pull the cap theres nothing in there and i cant find a leak or puddle or anything. i've added the UV dye with no luck.
help me out here guys i need to figure this out and fix it asap now as its impacting my ability to get to work.
