$483 with shipping.
Looks great! Have been considering one myself. Was it easy ton install? Does it make a big difference on the tailgate openning and closing, etc.View attachment 10582 View attachment 10583 View attachment 10584 Needed to mount 285/75/16 to match tires on the ground. After much research and recommendations on this forum, went with the Exogate.
Thanks. After looking around, it was also the cheapest option over a decent rear bumper and swing out tire carrier. I think this will. E more convenient also.Not bad at all. This is ultimately what I will end up going with. I wanted the OR-Fab tire carrier, but I am sick of waiting for them to "restructure" as they claim they are doing. They've been "restructuring" for over a year now with no ETA in sight.
After reading all the comments about installation, I went ahead and bit the bullet and let a local 4 wheel shop install it. He told me in advance it would be one hour; however they haven't installed one of these on a TJ. Lots of JKs. Took them 3 hours and still only charged me a one hour rate. $95Looks great! Have been considering one myself. Was it easy ton install? Does it make a big difference on the tailgate openning and closing, etc.
8 1/4.Would you do me a favor? For the hinges, what is the measurement between the bottom of the top and top of the bottom hinges? I'm not worried about the backing "spacer" plate. Thanks!!!
This looks great BTW!
8 1/4.
Top of the upper nut on the lower hinge to the lower nut on the upper hinge is about 6 3/4 inches.Thank you very much! One last question . . . Is that taking the distance of the nuts holding the hinge into account? I'm asking because I have the Savvy LED tail lights and that looks like it might be to narrow for them. I'm headed out to measure them now.
Is there reinforcement on the inside, behind the hinges? Also, if one just did the hinges alone with no tire carrier, would that eliminate the backing plate behind the hinges?
Yes. Tied into the roll bar bolts. The OEM tire carrier is used with the Exogate. Thanks for the compliment.Is there reinforcement on the inside, behind the hinges? Also, if one just did the hinges alone with no tire carrier, would that eliminate the backing plate behind the hinges?
Looks great, by the way.
Yes sir. Didn't find any other vendors that handled it.Assuming @DC0046 went with the GR8TOPS Exogate, they sell just the heavy duty hinges as well http://gr8tops.com/shop/jeepmodels/wrangler-lj-2/tj-heavy-duty-replacement-tailgate-hinges
Yes, I know they offer just the hinges. I am seeing a backing plate in the photos of the HD tire carrier kit, so I assume that the reason for that is to space the hinges out the same as the tailgate reinforcement plate that the tire carrier mounts onto, as well as reinforce the hinge mounts...Assuming @DC0046 went with the GR8TOPS Exogate, they sell just the heavy duty hinges as well http://gr8tops.com/shop/jeepmodels/wrangler-lj-2/tj-heavy-duty-replacement-tailgate-hinges
I am having this same problem! So my spare sits in the garage until I give up on OR Fab...Not bad at all. This is ultimately what I will end up going with. I wanted the OR-Fab tire carrier, but I am sick of waiting for them to "restructure" as they claim they are doing. They've been "restructuring" for over a year now with no ETA in sight.
