Ok need some advice or help with a starter install. New starter and the flywheel is making contact with the starter body!! What can I do?
Sounds like you got the wrong starter.
I don’t have the old one and I ordered new one from extreme terrain. The refurbished one from autozone did the same thing.That sounds like the new starter may have different housing dimensions. Mic the old and the new one and check. I'd return it for swap.
I ordered a new one from extreme terrain. Specs for a 06 Jeep Wrangler 2.4L. Doing the exact thing as the one from auto zone.Sounds like you got the wrong starter.
The starters changed through the years I believe. If I had to guess, the one you ordered is for a 4.0 possibly.
Can you post a link to the exact starter you ordered?
Crown Automotive 56041436AC56041436AC - Starter for 2006 2.4L
56041012AE - Starter for 2006, 4.0L, with manual transmission
56041914AC - Starter for 2006, 4.0L, with automatic transmission
It’s a possibility. I’ll check because turning the Engine by hand it seems to catch in one particular place.How do you know it’s the body hitting the flywheel and not worn ring gear teeth? Remove whatever starter you have installed and look at your flywheel for damaged ring gear teeth. You will have to turn the engine several times to inspect all the teeth.
Since the engine normally stops in one of several places, it sounds like worn/damaged ring gear teeth to me.It’s a possibility. I’ll check because turning the Engine by hand it seems to catch in one particular place.
Is that going to require a new flywheel? Possibly?Since the engine normally stops in one of several places, it sounds like worn/damaged ring gear teeth to me.
The short answer is yes.Is that going to require a new flywheel? Possibly?
Great!! That’s going to be a very expensive fix!!The short answer is yes.
You don't want to have the flywheel resurfaced. The FSM specifically warns against it. The flywheel has a slight conical shape (can't remember if it's convex or concave) to make clutch engagement smoother. Resurfacing will eliminate that feature.I’m seriously thinking that a bolt on the flywheel is loose or come completely out. I’m going to drop the transmission and take the flywheel completely off and have it resurfaced also.
