New tire sizes?
bvahlberg
Lansdale, PA
Hi! So I recently got a new jeep (2005 Wrangler). It has a 2” lift and currently has 31x10.5r15 BFG KO tires on it. However, I need new tires desperately and I’m a little confused on what sizes I can comfortably fit. I heard 265/75r15 will work, but just looking for extra opinions. Thanks!
31x10.5r15 and 265/75r15 I believe are about the same size. I am thinking 32s would be an option.
Those two sizes are virtually the same. I think metrics usually run a little truer to size, but that could vary by brand. With only 2" lift, anything in the 31/32" range would be a good fit I would imagine.
31 are great road size an light trailer work low road noise etc. If you going to hit the soft dirt or need to get through some nasty off road do 33" with more aggressive tread but if its your DD and you dont go off the road alot id recommend 31" BFgoodrich all terrains i liked those and the noise wasnt bad.
And dont get to silly with the width keep it 10.5 if you dont want rubbing I had 35x12.5 on my old 05 cause i was all over the rocks in Colorado but on the road trying to turn it was a pain.
