Hello,
I’ve been reading quite a lot of threads on the forum and just today decided to join the forum. It can become a bit complicated reading older threads on a topic as there’s a lot of discussion that’s hard to keep up with everything, being completely new to this..
I am seeking some advice for my recently acquired Jeep sahara 2001 with a 2.5” lift with 30” tires with dana 30,35 3.07 axles.
The doubts I have are:
- Since I have to replace my rear axle, is it recommended to change gear ratio at once?
- How much transfer case drop do I need? And/Or is an upgrade to SYE needed?
- Rear shocks are rubbing against the spring base, is flipping the shocks the correct solution?
- Rear track bar is touching the exhaust, do rear track bar relocation mounts exist for this or does this have to be fixed with the exhaust?
- Do I need adjustable or fixed control arms with the 2.5” lift?
