So I picked up a new to me 2005 Rubicon. It was barely drivable. Severe bump steer/wobble/drift, you name it. After doing a lot of research on here, and physically checking the Jeep, all 4 shocks were bad. Zero dampening. Replaced with Bilstein 5100. Drop pitman arm was replaced with a factory one. All steering linkages was replaced with the Currie set up. I believe it has a 4" Rubicon express lift. All 8 control arms were removed and all bushings replaced. All Johnny joints were rebuilt. The rear axel was 3" left. I re-centered the axel. All 4 tires have 500 miles on them. This is an AZ rust free jeep in great condition. The previous owner just thought that's how Jeeps drove I guess. All new sway bar bushings. Both front and rear track bars are adjustable, BUT they are attached to the factory locations. After doing all of this and getting an alignment. I am 80% better!! It drives good. But it still has a slight wander. After reviewing the alignment sheet, what are your thoughts to get it as good as new again?? Or am I there considering the lift?? My thoughts were getting both front and rear Currie track bars, lower adjustable control arms in the rear to adjust the thrust angle (top arms are adjustable and all lowers are fixed). The tech couldn't get the caster at 5' as the cam bolts only gave him 1' and he wouldn't take off the arms and adjust them. I thinks that it...…
If I wanted more caster, would I extend the top front arms or retract them?? Thanks for your time...
