I have checked vacumn lines and all looks good.
Have A/C and heat.
Defrost blows strong against windshield.
All other settings only blow air at the floor.
Blend door/ actuator issue?
I am getting a flutter noise on all settings.
Possible vent blockage.
Thanks,
Bob
Thanks for the info.
Vacumn lines all look good.
For a 2002 TJ is the blend door and actuator behind glove box,
or is it uner the center conssole.
Not 100% sure on the 2002 model. Have you checked your vacuum lines where the go under the battery? I know that’s a common place for them to fail.
I think this write-up will work for you, as it’s for a 97, which would be the same as an 02:
https://wranglertjforum.com/threads/how-to-fix-heat-ac-air-not-blowing-through-center-vents.2887/
Does anybody use these anymore?View attachment 45544
haven't been able to confirm line to resevoir under battery is good.
I have crawled under jeep three different ways and i don't see anything.
If I pull out battery can I see and check it?
It’s ironic, but I have a 2002 with the opposite issue. Air from the vents but nothing out of the defroster. I haven’t tried to figure it out yet.
Works on vacuum lines and actuators also
It's a brake bleeder but it's great for checking vacuum lines and map sensors and purge valvesDoes anybody use these anymore?View attachment 45544
