2006 LJ Rubicon will not crank from the ignition, I get dash lights, nothing else, no relay clicking, no power to starter, here is how I’ve troubleshot so far. The short term goal is just cranking with key.
-Multimeter on battery, tests good @ 12v
-jumped starter relay, engine cranked
battery/starter working.
-Checked all relays by switching them with horn and honking, relays working.
-Checked clutch safety switch with multimeter, working.
-Rebuilt Ignition from cylinder to switch after recovering from thief drilling it, cycles fine.
-Ignition harness probed and tested for power, power coming out when key is turned.
-Checked and cleaned engine block and firewall grounds.
Short of ripping the entire thing apart to thoroughly check all wiring from ignition to relay, does anyone have any other ideas?
-Jarret
-Jarret
