- Joined
- Apr 21, 2016
- Messages
- 150
I've noticed that replacement fuel tanks aren't available? If this is true, what are guys or gals doing that need a tank?
Yes it is... Rare illusive 1996 model hehe.Is your model year top secret or what? With that a model # for the tank can be determined to maybe find one that will work.
I asked for the model year so I could look up the tank p/n which is 52100484. I couldn't find it in my usual sources but at least that p/n will help. It is surprising that 2002 and older tanks are fairly easily found but not so for 2003 and newer.
The newer tank has more plastic connections for the smog system and it's a bigger PITA to remove & replace.Wonder what the difference is between an 02 fuel tank and an 03 tank?
I have the 15 gal tank in my 1999 TJ, and I wish it was the larger 19 gal tank. I see some 19 gal tanks on eBay used for approx $75 - is that a good deal?
The 15 gallon tank is pretty rare in reality. It is only very basic stripped down TJs that sometimes have the smaller tank.I have the 15 gal tank in my 1999 TJ, and I wish it was the larger 19 gal tank. I see some 19 gal tanks on eBay used for approx $75 - is that a good deal?
The 15 gallon tank you have is actually the same as the 19 gallon tank except that has a longer vent tube so it cannot take more than 15 gallons. If you drop the tank, remove the fuel pump assembly and stick your hand into the tank and cut off about 3 inches of the plastic vent tube with a razor knife you will now have the 19 gallon tank. I did the same thing to my 99 when I replaced the fuel pump. (I used a pump for the 19 gallon tank)
Some erroneously think they have the smaller tank because the gas gauge is notoriously inaccurate and can indicate the fuel level is way lower than it really is. My gauge consistently shows the tank is empty when there is actually 4-5 gallons in it. I wait until the pointer is all the way to the bottom before I refill and even then it rarely takes more than about 17.5 gallons or so.
If I refilled at the normal Empty mark I'd think I had a 15 gallon tank too.
