Howdy all,
I've been having some ongoing issues with my TJ. Hoping someone can lead me in the right direction with solving the problems. First I had a loud chirp/squeak coming from the engine. Discovered there was a rocker arm that was dry and rusted. Changed that pair of rocker arms and pushrods. No more chirp but also discovered that no oil is coming up through any of the pushrods. Also, there's a crack in the head between cylinders 3&4. A very small amount of gunk at cylinder 4 valve. No build up anywhere else on the head. Oil pressure is good. Checked it with a manual gauge. I've run seafoam through the oil. Checked the oil. Oil looks good and clean. There is a light lifter tick. I have not been able to find any sort of definite solution or series of things to check. Is it likely all the lifters are clogged up? Any education about this is greatly appreciated!
