hey gang, so on my 00 wrangler 2.5L has had a few issues lately that i thought was my fuel pump going bad (which it was) so i replaced it and everything started running worse. At first i thought it was something with the fuel system, like maybe a leak in the line and even re-replaced the pump incase that was a dud.
Ususally it would just take a WHILE to start and run fine, until the other day when it would loose power while on the highway and it was only able to manage to just barely putter back home. So like i said i rereplaced fuel pump and lines and that all has good pressure now buuuuut still wont crank!
Turns out i've got no spark. I dont even have power going to the coil. I've replaced relays and all fuses seem good. I checked (but didnt clean) my grounds (because thy looked fine)
I'm kind of at whits end here. I dont have any idea what could be the issue. Crank sensor is fine (checked it with a meter) engine cranks, fuel pump...pumps, just no power to the coil.
From what ive read it could be PCM buuut wouldnt everything else not work? is there some other fuse or relay to check? it was all running pretty fine before i decided to switch out my dying fuel pump (had to do the prime on/off 4x trick to start, and it always ran fine) I cant imagine my electrical system to just get wonky outta nowhere (unless i shorted out something, but again wouldnt everything not work if i shorted PCM?)
HALP MEH!
Mahalo
HALP MEH!
Mahalo
