Hi, new member. First post.
I recently purchased a 1998 TJ 4.0 with 53,000 miles on it. It runs phenomenally well but won't start without starter fluid. I checked the fuel pressure at the rail and I'm getting 0psi. The fuel pump fuse and relay are good. After starting with starting fluid it runs like normal and has no issues otherwise. Is it normal for the fuel pump to fail in a system with such low mileage? Obviously it's a relatively old Jeep, but I wanted to see if anyone has any insights here before I drop the gas tank to replace the fuel pump.
Any advice is greatly appreciated. Thanks in advance. (I know there are numerous posts similar to this one, but none seemed to have the exact set of problems I'm having.)
