Is this on one side or both sides?
How thick are your wheel spacers?
If this is on both inside and outside of the tire add a couple psi to the tire to force the center to make better contact on the road. If this is on the outside only it can indicate a bent axle or bad ball joints or even bad bearings. It is possible that you have bent the inner 'C', but that is unlikely.
What is your wheel offset? If it's only on the outside of your tires, I'm just thinking, with your spacers and maybe incorrect wheel offset, your scrub radius is jacked up too far positive and wearing the middle to inside of your tires. Not typically an issue with 1.25" spacers, but significantly incorrect wheel offset maybe would exacerbate it.
That's pretty close. I believe ideal backspacing for TJs is 3.75" and you're at 4.25" which isn't too bad. There goes my theory.They are stock wheels, if I recall they are called Ravine wheel. 15x8", 5.5" backspacing, offset is +25mm from research.
Generally speaking when you only wear the inside of the tire it means you have overinflated your tires. but if youre running 25 PSI thats not the case.
How wide are your wheels and what is the width of the tire 33X(This number)R15
