As with similar threads on the forum, my check light has come on and the voltage gauge starts low then drops to zero. I have confirmed the battery is not charging. Following advice from the threads I have read through here I have checked the battery, cleaned and re-connected the battery, cleaned and reset every ground I could find and had the alternator bench tested at 3 separate parts shops (tested good). So now, at at the point of turning to the ECM thinking of regulator. My questions are:
1) Am I headed the right direction - is the ECM the next logical step or are there other steps I should pursue first?
2) If ECM is the next step - any suggestions on where/how to purchase a new one so I get the right component and dont screw something up?
3) There are a number of comments about an external regulator setup - is this a better way to go? If so, any links to a good instruction set a dummy like myself can follow?
Thanks in advance for your help...
