That's fine, I will concede almost every point with the caveat that while you're correct, the percentage increase by which there is more of those things inducing wear blah blah is very small. Your position is yet again secure, you pick some very small differences and make that molehill a mountain to die on.It's right there in multiple posts. Including the one you just quoted. Larger tires get worse mileage.they wear out other parts faster and said parts need to be stronger and more expensive for what those tires are capable of.they are less likely to have your wife,mother,kids or anyone important want to ride with you. Almost every metric that a vehicle that gets used often is judged by.
The only one that you are blatantly wrong about is the family bullshit. Every 35" tire build I've ever done is a no buts build and that wouldn't change if it were 33's. The no but means I can, will, and have tossed the keys to anyone that is going to drive it and that's it, no buts, no warnings, no watch out for this, or watch out for that, nothing, just like any other car. I'm guessing you have been around some very shitty 35" builds or did one and went back to smaller tires.
Come on now, that's bullshit and you know it. There's no fucking misdirection there, if we don't apply similar build levels to the rigs being discussed, then there is no basis for comparison. The misdirection is coming from you. I made the point about a Zone lift build with stock control arms versus the rock eater, surely you are able to understand why that matters, or no?33" or 35,36,37,42" tire builds don’t need to be on the same build level. That wouldn't make sense on mulitiple levels . it's just more misdirection.
No, I went silent because I realized that you state a position, you stay there, and that's the end of it and I also realized that while the gearing could be done, you won't ever do it, so it became a waste of time. You become the tail that wags the dog with a single example out of 1000's to the contrary and that gets tedious.As far as the compression braking discussion it was laid out quite clearly that without moving to an overdrive auto(which you've admitted isn't an easy task in a 97-02.and you haven't done to your standards) your suggestion of simply gearing down to compensate isn't useful unless you want to forego freeway speeds. The rpm numbers aren't hard to grasp.You did not acknowledge that the gear ratio spread in a non overdrive auto has compromises.
You did however go silent after resorting to name calling.
