I have a 2000 4.0 manual. I started getting intermittent stalling while I was driving, I already did fuel pump checked pressure, compression, new spark plugs and wires are good and injectors have been cleaned out, as well as a new camps . Haven’t done the crankps yet or checked the distributor out. Scanner shows it threw an evap purge valve code when it died as well as auto shutoff, and fuel pump control circuit but after the code is cleared it doesn’t come back til I stall the engine hard enough to kill it. Also fuel pump has been pulled back out and inspected and the sock doesn’t have anything in it yet and this even happens when I’m on 3/4 to a full tank so I don’t think air is going into the pickup either.
