Recently purchased a 98' sport after years of wanting one. Bedlining the tub so took the seats out and planning on painting the panels with SEM so removed them. After taking panels off I noticed a weird aftermarket switch under the dash.
One end of the switch runs to the back of a red/black wire on a pin connector of the climate controller.
The other end runs through the firewall into the engine bay...
Splices into a fuse covered in electrical tape...
Then into what appears to be stock wiring again...
Stock wiring runs here...
And here at the T section you can see in the background...
Any ideas as to what in the heck this is? All of the wires are spliced like crazy and doing funky stuff. Even the stock wires are in pretty bad shape with bare wire exposed etc.
To add additional mysteries...
There is also this one that runs from what appears to be a stock ground to the frame of the dash...
Over to this rat's nest that came apart during inspection...
Then into the back of another pin connector from the climate controller...
Any guidance/advice would be incredibly appreciated. Hope I haven't bitten off more than I can chew on this, but I can't see this and just tuck it back into the panel with good enough conscience to sleep at night.
