I did rear main seal, valve and oil pan gasket in one go.
Valve cover is holding up good, other two (or one of them) are leaking worse than before i touched it. Tbh i dont even know if other two were bad since the top one was leaking so much.
After the 1st gasket change i lost somewhere around a quart of oil in 50 miles.
After the 2nd change things are much better, but still i see a drop going down every 10 -15 seconds
I took my sweet time on rear main seal to make sure everything is kosher, twice, so im ruling it out of the equation.
For oil pan gasket a FelPro was used. Both times i used red rtv on both the top and the bottom of the oil pan gasket, at the front of the block and where the rear bearing cap. just like in the pic below.
Both times that i have done this, i noticed that gasket did not want to stay on the lip of oil pan where it mates with bearing cap.
During the 1st change, i did not pay attention to that area, and i think that gasket slid off and missed the grove in the bearing cap. Second time i did my best to be more careful, but there is only so much that can be done once the oil pan goes up.
Oil used is synthetic, i have read plenty of theories on it, but theory is a theory.
Don't know how to feel about the use of rtv since the original did so well for 120k miles without it.
Im open to suggestions guys and girls, i want my 3rd time being under there to be the last time for next many many miles.
