Posting this to ask for some assistance on a friends Jeep. He has a 05+ superduty front axle with Artec’s high steering setup.
The last few trips out, his tie rod jam nuts have broken loose. This goes unnoticed until the movement in the tie rod causes his PSC cylinder fittings to loosen up causing him to loose fluid. Once he notices he no longer has hydro assist he checks the fittings and finds them loose. He tightens that back up and notices the jam nuts on the tie rod are loose. Fills the reservoir back up and gets back on the trail. The PSC lines were locally made. I’m unaware if this could be an issue with the type of fittings on the end for the cylinder.
Lastly I don’t know enough about this setup to offer a permanent fix. So I asked him for a photo of his steering in order to help figure out why this keeps happening. Not sure if this is an ideal setup or not. Just trying to help him fix the issue. Any advice is appreciated.
