I just had the T-case and differential fluid/oil replaced in my 2006 TJ. I have the 42rle trans and would like opinions on having the local Valvoline oil change place flush out the old fluid and replace. ATF 4 of course. Is this a good idea, or is it necessary to go to a trans shop and have the trans drained and a new filter installed, then new fluid. The Valvoline guys told me the filter is just a screen and the flush method with leaving the filter in place is fine, it will get cleaned out. I'm not sure I buy that. I'm also not sure I buy that the filter is just a screen. I suspect there's more to it than that. I've become reliant on the advise found on this site.
