I'm new here but through searching I haven't been able to find another thread here like this. I just replaced my front turn signals with LEDs when I installed the Genright HiLine Flares. Now when I hit the left turn signal I get the left turn signal flashing normally, but the right running lights also flash but with Hyper flash, along with the license plate light. when I signal right the right rear turn signal flashes normally, but the left running lights also flash but with Hyper flash, along with the license plate light. When I turn the headlights on this stops in the rear but the front running lights continue at hyper flash. The front turn signals are not flashing under any of the above conditions
I changed out the flasher relay with the one Genright sells when I did the rear turn signals, and everything worked fine then. I've checked with a multimeter and everything seems to be wired up correctly, and the front turn signals are getting power when they are supposed to. I have tried a different set of LED front turn signals and still have this issue. I have been through and checked every fuse in both fuse blocks.
This is in a 2005 LJ
