Perhaps. I don't know how ORIs compare to good shocks.... They say they switched from coil overs to ORI and it was the smoothest ride they have had. ....
Most shocks can be used as limit straps. Whatever method you do use, it still needs to limit down travel in order to prevent an over extension. ORIs don't magically change that fact.... .... Also they mentioned no limiting straps....
The bump stops, wherever or whatever they are, still need to be correctly positioned to limit up travel in order to prevent interferences. ORIs don't magically change that fact.... Also they mentioned no ... bump stops....
... or anti rock needed.
All this tells me is that ORIs have enough damping to slow body roll. That is a valving discussion that is not exclusive to ORIs. There is more to anti sway bars than just controlling body roll. If they are saying that, then they are not understanding the full benefits of having connected front and rear sway bars.
My point is that ORIs, while a very neat and tidy suspension system when done well, are not some magical pathway to an amazing Jeep. They require the very same setup and detail as any other well sorted suspension.
Seriously spend some time understanding how to outboard the rear shocks on a traditional coil and shock suspension. The basic setup is nearly identical and the goals and principles for good performance are the same.
