The Jeeps been running great, so I hooked up my trailer to take it to DMV for its vehicle inspection to complete the title registration. 2 miles into my journey I get a check engine light P0052. I pull over grab my OBD2 scanner it reads P0058 O2 sensor 2/1 hearer circuit high, looking this up it says cylinder bank opposite cylinder 1 O2 sensor after pre cat higher than expected voltage. Try to clear the code and it will not clear, drive home and put the trailer away, clear the code and go for a test drive and the Jeep runs great no check engine light no codes? Only thing different is I’m not connected to the trailers electric system and obviously I’m not towing the trailer. The couple times I did tow the trailer before the new transmission, driveshafts and muffler I had no problems and don’t really see how any of those are related? The one emission circuit that has never closed is the HTR and again not sure if that is related at all, I believe there is some service bulletin regarding the HTR not clearing but haven’t gotten into that yet, I’d passed smog inspection already.
All 4 O2 sensors were replaced 2 years ago with factory units when I replaced the pre cats and I’m stumped, could this be extra fuel pumping unburned being picked up by the bank 2 sensor 1 from the extra load of the trailer? And if so what would I do to correct this?
