B
Bill M.
Guest
Not good.
Not good.
Already replaced the OPDA & had my shop do a sync & relearn. I was going to drive with the scanner hooked up to try & catch the blinking CEL, since it doesn’t leave a code.I written about this many times, done lots of testing and I am still learning how to solve the problem you have. Your best approach is to find Mopar sensors, look on eBay. While you are at it replace the OPDA, then have a shop sync the CPS and CKP and finally do a relearn. If that doesn't fix the problem then talk to Wrangler Fix about a rebuilt PCM.
My biggest worry is putting money into a new PCM in, after I found the plug tampered with. Hopefully, scanning while I’m driving will give me some kind of answer. I don’t want to keep throwing parts at it.Do what @Bill M. said.
Call WranglerFix, search on the Forum and you will him. You likely have a fried PCM.Nope. Not good, at all...
I spoke with Mark a few days ago. Looking at $950.00 for one, since I have a manual. The wiring harness is my concern...Call WranglerFix, search on the Forum and you will him. You likely have a fried PCM.
The wiring harness is easy to test. If you have 5 volts at the sensor connection to ground then you are good power and ground side. If you are getting a known good signal at the PCM then the signal circuit is good. With both these circuits good then PCM is usually good.I spoke with Mark a few days ago. Looking at $950.00 for one, since I have a manual. The wiring harness is my concern...
Did you figure out your problem? Was it the ecm? Going through a similar experience with my 05I spoke with Mark a few days ago. Looking at $950.00 for one, since I have a manual. The wiring harness is my concern...
I am leaning towards taking the step and buying a refurbished one. I already talked to Mark from wrangler fix. A local computer shop has mine now, hoping they can confirm it is bad before I order one. Thanks for sharing your thoughts.This sounds pretty close to my previous issues and I ended up doing a new PCM, none of those issues since! (06/manual)
Replaced my ecm with wranglerfix.com. So far so good! Mark was GREAT to work with.Did you figure out your problem? Was it the ecm? Going through a similar experience with my 05
Mark is definitely the way to go.I am leaning towards taking the step and buying a refurbished one. I already talked to Mark from wrangler fix. A local computer shop has mine now, hoping they can confirm it is bad before I order one. Thanks for sharing your thoughts.
