I have a jeep TJ 2005 with the 42rle with the p0740 code only when the overdrive on doing 2100 revs on the highway doing 60mph/100kmh but when the overdrive is off and doing 2900 revs doing 60mph/100kmh the engine light doesn’t come on. I have replaced the solenoid pack, replaced the PCM with a wrangler fix, looked through as much wiring as possible and couldn’t fine anything also have added a trans cooler and done a trans fluid flush and changed the filter. Its either I replace the torque convertor with a new refurbished one, don’t use the overdrive button or put some tape over the engine light. What do you Think the problem is.
Cheers Will
Cheers Will
