I’m soldering a onto a circuit board right now. I’ll get back to you later today.Well I got the cluster cleaned and put in and out a few times. Started up but no gauges/radio/dome/under hood light still.
Did you perform the voltage check described in post 16?Well I got the cluster cleaned and put in and out a few times. Started up but no gauges/radio/dome/under hood light still.
lol, I understand. So it would be safe to say you don’t know how to read a wiring diagram.Lol...all 1400 some pages...lol.
It's so complicated for me. I'd like to take a match to it. So I have power on the left side of the instrument cluster but not the right. Looks like maybe the headlight switch may be involved?
Let me look at the wiring diagrams and connector pin outs and I’ll walk you through it. Give me some time. I will get back to you.Yeah that would be accurate. I'm trying though. Looks like the right side connector of the instrument cluster is the one I needed power from??
Do you have power on both legs of fuse 17 in the PDC under the hood?
Check for power on pin 3 of connector 2. It’s a 20ga orange wire.Yeah I've got 12v to both legs of fuse 17
I'm not getting any power to connector 2.
Not even on pin 9 of connector 2? Pink with a white tracer.I'm not getting any power to connector 2.
I don't even see a pink/white wire going into connector 2.Not even on pin 9 of connector 2? Pink with a white tracer.
Check pin D12 on connector 108.I don't even see a pink/white wire going into connector 2.
