Parking brake warning switch appears operable / doesn't set off buzzer
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
2003 TJ
Manual
Has anyone experienced this
I'm straight grounding it now to test.
Andy G
The parking brake never set the buzzer off on either of my two TJs, I don't know that it's supposed to. Any buzzers in my vehicles always get disabled anyway, I hate 'em and don't need 'em.
Me too generally, but I keep driving around with the parking brake on for some reason, mostly at night - I need to be more mindful.
I repaired the connector at the proportioning valve just now , will report back , if for no other reason than to share what I learned .
Thanks Jerry !
Case closed - it was not the copper/ brass ground type switch under the console .
The plug at the portioning valve is connected to this circuit .
Mine had an issue back when I was replacing the steering shaft .
I repaired the connector, works as designed .
Works fine now.
