Cbrianroll TJ Enthusiast Supporting Member Joined Mar 27, 2023 Messages 123 Location Washington Apr 14, 2023 #1 This was zip tied under the master cylinder….no vacuum line floating around the engine bay but one is capped off under the intake…
0 03coloradowrangler TJ Addict Supporting Member Joined Jun 25, 2019 Messages 1,178 Location Mid Michigan Apr 14, 2023 #2 vapor purge solenoid iirc one of the vac lines runs directly to the intake manifold barb.
OP Cbrianroll TJ Enthusiast Supporting Member Joined Mar 27, 2023 Messages 123 Location Washington Apr 14, 2023 #3 Thank you much….found some hose and have it connected again.
