Passenger Window Weatherstrip Leaking
TNutty
USA
Hey guys! I've been dredging the web and this forum for possible solutions to my issue for about 2 months now and figured it's time to see if anyone has any remedies.
My passenger door leaks water from the exterior window weatherstrip/scraper, and it drains into the inside of the door, out to the bottom and then onto the floormats and carpet. I'm not sure what else to do as this is the only location the leaks are coming from (verified with a hose and the door trim panel off).
1. I removed the original strip and reinstalled, did not fix issue.
2. Bought an OMIX-ADA weatherstrip, it was not cut properly in the window frame.
3. Bought and installed a Mopar weatherstrip and seated it correctly in the window frame, the window still leaks.
If anyone has had a similar problem I'd be interested in hearing what their remedy was.
Cheers (y)
All the old Jeeps I’ve owned leaked. I learned to live with it. I did paint inside of doors with POR-15
