Recently my wife's TJ started to stall on her at random times. There didn't seem to be any traceable pattern to it. I read as many of the threads as I could find across most of the wrangler TJ forums and tried a few fixes like cleaning the idle air mixture solenoid, and replacing the TPS, but it felt like an electrical problem to me. While working on it today I discovered that if I wiggled or even just pressed lightly on any of the 3 plugs of the PCM I could make it stumble and even stall. So it seems to be bad connection in those plugs. I pulled the plugs and inspected them and found no visible issues So the question becomes, is there a way to make those plugs contact the pins better? Or is it even the plug? Could there be an issue with the PCM itself?
