Is there such a thing as plain 85-140 gear oil? No modifiers or additives? ARB recommends this for their lockers and even though the others may work I would like to use what they suggest.
What do they suggest? Share us the detailed scoop!
uh-oh, I used this for so many years on my TJs gears from the wally world.
99.9% of the gear lubes people run with their ARB Air Lockers and just axles in general have the friction modifier additive. I suspect who wrote that advice on ARB's website did not realize that. The friction modifier's presence has ZERO effect on an ARB Air Locker or any other locker or axle for that matter. That's why it's present in most gear lubes, you have to hunt for a GL-5 gear lube that doesn't have it.
You gears will definitely run cooler if you run a conventional gear lube. I run Valvoline 85W-140 conventional gear lube with my air lockers but the exact viscosity is not critical in the least.
Lastly, where did you find that information advising against friction modifiers? I've been on the ARB sites and in their FAQ sections on & off for years and I've never seen that or heard it. Their webpage at https://www.arb.com.au/assets/air-lockers/6-01.pdf doesn't mention that requirement and neither does their operating and service guide at http://www.fuzzymuzzle.com/Car/Gear_Install/ARB_AirLocker_Manual.pdf
Ok but where? Neither their installation guide nor their operating & service guide mention that at all and those are the official guidelines from ARB. I gave links to both of them in my above post #8.It was on their Question and answer board
I suspect the page you read that on was personal opinions. ARB itself doesn't recommend against the use of gear lubes with friction modifiers in their official manuals as linked to above. A friction modifier has no effect on any locker like an ARB, Detroit Locker, lunchbox locker, etc.I found a link on google search that took me to an Aussie forum. Trying to find it. I looked at your link and it is not the same. Your link looks newer. Maybe a bogus page?
Aussies are sketchy to begin with... I trust what JB is saying, he's from Escondido, you couldn't go wrong.I found a link on google search that took me to an Aussie forum. Trying to find it. I looked at your link and it is not the same. Your link looks newer. Maybe a bogus page?
