I broke this plastic part at the very bottom of the heater box which one of the heater cables attaches to. I’m having trouble finding the part name or number. Any assistance greatly appreciated!
Those are the levers for the side doors. The bottom door is a little different. But thank you, that helps my search.Here you go:
https://www.amazon.com/dp/B000FQ225U/?tag=wranglerorg-20
Less than $8 with free Prime shipping.
The ridge around the outside is a cam lobe that sits against some sprung metal plate. It matters.Those look different than his. They don't have that little ridge thing around it. I don't know it that matters though.
On mine, I drilled a hole where the peg used to be and put a small (#6) screw and lock nut with washers to grab the cable. I just did it yesterday, so I haven't had the chance to really give it a workout
Great idea. I will install this today and report back!On mine, I drilled a hole where the peg used to be and put a small (#6) screw and lock nut with washers to grab the cable. I just did it yesterday, so I haven't had the chance to really give it a workout
Yes, it’s really smart. Thanks.Here's mine. Left just enough slop in the lock nut that nothing was getting hung up, but also the cable doesn kink or get cattewhompass
The part number is 4864 990 but seems to not exist anymore. I will have to fabricate something.
Get one 3D printed. That's what one guy did.
https://www.wranglerforum.com/threads/heres-a-cad-model-for-97-tj-blend-door-lever.2385555/
He shared the 3d printing file near the end of the thread.
https://www.printables.com/model/645929-wrangler-tj-97-blend-door-lever
