I'm trying to get my rear defogger to work. As far as I can tell, the lines might just barely warmer than the glass (I'm not even sure if I was just imagining it) but not warm enough to actually work.
Here's the situation:
-The light on the rear defogger switch illuminates when I press it. (I think this rules out a problem before the relay?)
-With the defogger switch "on" and illuminated, the voltage measured between the two "terminals" on the rear window was about 9 volts, though one reading I got 10 volts.
-The fuse in the glovebox panel looks fine and passed a basic continuity test with the multimeter. I haven't tried replacing it.
-I tested the conductivity of the strips on the glass, they all seem fine.
The FSM says to test part of the instrument cluster and the relay in the engine compartment. I'll test the relay, but here's a thought for you all - could this be dirty connectors at the rear window causing the undervoltage and thus the shitty performance? Or is this 10 volt reading just a red herring because I'm incompetent and can't use a multimeter?
Suggestions for cleaning the connectors?
Thoughts? Where should I go from here?
Edit: it's a '97 TJ and as far as I can tell it's got the same hardtop it had from factory, and (obviously) is factory wired for it.
