I have a problem that developed recently on my 2005. I started noticing a creaking, popping, clicking noise while driving at slow speeds. After some experimentation, it seems steering-related. With the jeep sitting in the driveway running and my wife turning the wheel back and forth, the noise is reproducible, per this video:
I've checked the bolts on the steering shaft where it clamps to the splined input on the steering box, as well as the clamp before the support bracket. The support bracket itself is also tightly fastened. If I grab the steering shaft by the bracket, I can feel a small amount of play as it moves in the bracket, maybe 1/16" or so. I dunno what it should be, but that seems okay. The noise definitely seems like it's coming from closer to the steering box though.
With the jeep off and the wheels on the ground, I can't reproduce the noise by trying to turn the wheel (I can't actually steer of course, but if I put torque on it by trying, no noise). If I jack up the front end so the wheels are in the air, I can turn lock to lock without any noise, both with the jeep running and not running.
I feel like if it was something bad in the steering box, I would hear the noise when I turn the steering wheel with the wheels off the ground as well. I feel like if it was related to torque on the steering shaft (i.e. the support bracket or similar) then I would be able to hear it with the jeep off and me pulling on the steering wheel when there's more torque than with it running.
The steering pump has fluid, it looks okay, and there are no leaks.
I'm not sure where that leaves me.. Maybe the U-joints in the steering shaft? The video shows the forward U-joint and it doesn't look to me like it's binding up or jerking when the noise happens. I feel nothing at all in the steering wheel when the noise happens.
Any ideas?
Any ideas?
