I’m sure somewhat here has experienced this and cured it. Pops while turning. Track bar at frame maybe?
Also, check to make sure your springs are seated properly. I've had the front spring upper off center before and hitting the upper spring perch, making a horrible clanking sound going down the road.
Do you have a trackbar frame bracket? If popping noise happens when turning while not moving and you have one of those aftermarket front trackbar drop bracket that may be the cause of the popping. some of those brackets need to be welded on the frame.
x2. It's almost impossible to track it down by yourself, a helper would make pinning down the location so much easier.you might wan to have someone turn the wheel while you are down near the front to see if you can hear the location of the pop
I hear ya been there done that. Have you tried without the engine running. Steering wheel unlocked but engine off. Have the helper try to turn it hard both ways
