I recently acquired a set of Dana 44 front and rear axles already with ARBs and 4.88s. I have the rear swapped out and it is puking diff fluid from the vent hose. I filled it with 2qt and as far as I know that should not have over filled it. It does seem to be warmer than I would expect after 20 minutes of highway driving @ 70mph, but I don't know how hot is too hot.
I am swapping all the front brake components over to WJ in the garage before swapping the axle itself. Last night I could hear and feel a noise coming from the diff when either hub is spun. Common sense tells me it should be completely smooth with no noises. This is my first set of axles with ARBs so I don't know if what I am hearing and feeling is normal.
The axles came out of a TJ from an owner of a local reputable 4x4 shop. Hopefully I wasn't just being naive to assume they would have been set up correctly and would just swap in. Any input or suggestions would be appreciated, thanks.
