So, last Wednesday I posted here about a problem I was having with my TJ revving to the limiter instantly on startup. Thanks millions to mrblain, 89sandman and jeep_boss for their reply's and advice trying to help me solve this problem. I want everyone to know that I've been a maintenance worker most of my life so I like to think I'm not a total moron when it comes to troubleshooting problems. Just goes to show you how wrong you can be!
Here's the sequence of events. I took a systematic approach to solving the problem, I checked the throttle cable, unhooking it from the throttle body bellcrank and making sure that it wasn't binding and it was totally free. I crawled, stooped, crouched, stretched and contorted myself into a pretzel under the dash and engine compartment trying to find a vacuum leak. I couldn't perform the usual vac-leak check with propane or whatever because the engine was revving as soon as you started it. I removed the throttle body, cleaned it, cleaned the IAC, checked the TPS, made sure all the gaskets, o-rings and stuff were not leaking. No luck there. I read everything I could online about this issue, I read everything I could find in the Factory Service Manual about all the suspected components. I finally decided that it might be a problem with the PCM so I disconnected the battery on Friday night and left it off over the weekend. ( I know that's not necessary but Soaring season started this weekend and I was at the airport every day.). Yesterday, I went to work on the jeep again, hooked up the battery, started the jeep and she started and idled perfectly. Hurray!!! Then I touched the gas pedal and whammo, high revs again. About now, I'm getting pretty pi$$ed off. I grab a screw driver and flashlight and start searching again under the hood. I then move to the cabin to go through the vac leak check thing. Again. Drop my screwdriver on the drivers side floor, reach in to retrieve it, look up, and there it is, right in front of me. Moron. Nincompoop, Idiot. Novice. Now remember, I've been under the dash at least 567,842 times checking vac lines and in all that time I didn't notice this!!!
The floor mat, while behind the clutch and brake pedals, was in front of the gas pedal!!!! And THAT was what was messing with the throttle.
As you may notice I spent a whole day debating with myself on whether I should post this and confess to such colossal blunder. Hopefully, you all get a chuckle out of it. Basic troubleshooting: always check all the simple stuff first!
