I noticed a couple months ago that my lines were VERY dirty and that I was low on fluid. Since the Jeep is blown apart right now, getting a bunch of new stuff, I examined the P/S system a little more closely. What I found is not good, I think. My High Pressure line doesn't look like its routed properly because the jacket has worn away in a couple spots. I think the leak is coming from the return line. It had a dumb Oetiker clamp on it, instead of a constant force clamp and its pretty tight to try and get in there to give the Oetiker a squeeze to try and tighten it.
What say you Jeep Peeps? How much of this needs to be replaced?
If someone could take a picture of the top of the reservoir and how that steel tubing comes around, it would be appreciated! Thanks
