Hello,
First time posting here, but I have been lurking since I bought my first ever Jeep back about 6 months ago. I have used the forum to do some repairs and PM… from the heater core (fun job), to alignment, to an under-hood lamp. While changing rear diff oil, I found a sheared off bolt that had chewed things up a bit, and all the ring bolts were loose. No noise or slipping, but a few of the teeth had some visible damage. @Squatch helped me find a matching set of Dana 30/Dana 35 4:10’s (currently have 3:07) and I am getting ready to do the swap. From all I’ve read it’s straight forward. But I do have some questions I would like to get answers/opinions on.
Except for brakes (used axles have brand new rotors/calipers/shoes) I am going to replace shocks, all u-joints and control arms. The sway bar link boots are all dry rotted and cracked so I will replace those too, and anything else that appears worn as I start removing. Per the pictures attached, I believe I have a 2” lift in the front, and the rear is stock.
Is it worth putting a spacer in the rear springs? When I order the Rancho shocks, do I get the ones for 2-3” lift, or will stock shocks work? Confusing for me, as I do not have a 2” lift in the rear, only front.
Stock control arms should be fine, right? I plan on keeping the 32”’s and no more lift. I like the looks of it now. In the “A Beginners guide to lifting your Jeep Wrangler TJ” it suggests you have upper rear adjustable control arms and a DC driveshaft, or transfer case drop. Do not have neither now, should I?
The steering stabilizer, should that be replaced too? Rancho has one for under $50, so not too bad.
Any other things you think may be important for me to do or know going into this axle swap, do tell.
Thanks!
Thanks
Thanks!
Thanks
