Hey Guys. new to jeeps and enjoying my very first major problem. 06 LJ 4.0 manual 116K. I've run several tests and they all point me towards a dead PCM. volt meter and fuel gauge do not register (cluster passes self test though). my OBD2 scanner will not connect, and the SKIM light is on. I have verified none of the engine sensors are shorted and they all are being powered and grounded properly. I have verified that power and ground are being delivered to the PCM when the ignition is on, and when you turn the key to the start position there is + power delivered to the start relay coil. I've found however that the PCM is not providing the ground to the ASD and Fuel pump relay coils as it should when you turn on the ignition. also, at one point with the ignition in the on position the ASD and fuel pump relays were chattering in unison (they share the same coil ground from the PCM). sounded like a telegraph. so I think it's dead, but I'm looking for any guidance out there so I know for certain. Does anyone know of a specific test(s) I can run to verify it is in fact dead? Note I did run the ASD relay circuit test procedure in the TJ Drivetrain manual (best I could without the DRBIII), and the conclusion there was to replace the PCM. any advice? would like to know for certain before I buy something... thanks!
John
John
