Good morning everyone!
First time poster here. Loving this resource so far. Greatly appreciate the service manuals.
I have a No Crank condition.
So far, I have; Ignition Cylinder (Replaced), Ignition Switch (Replaced), Neutral Safety Switch (Bench Test - good), Starter Relay (Bench Test - Good), Starter Solenoid / Motor (Bench Test - Good), Power Dist. Relay (Replaced).
After digging through the Service Manual I have a nice list of 5v circuits to test (oh, joy!) that could cause the PCM to trip the ASD (not getting any signal to the ASD from the PCM), or just not function. I didn't find a testing procedure for the PCM itself in the service manual, so either I missed it in the 1678 pages, or it's not in there.
My initial search had me testing the Ignition Sense, and I was able to confirm 12v from the Neutral Safety Switch to the PCM (C3, Pin 21), but I am not getting enough Voltage out of C3 Pin 38 to close the Starter Relay circuit (Getting 31.5mV's w/ Key On and Key Start, 0.0v at Key Off, and 0.2 Ohms between Pin 38 and Relay).
Tonight I am going to test Ignition Switch to the PCM.
Any insight or direction would be greatly appreciated.
o7
o7
