I just finished installing the Sound Ordnance B-8PT which has an older yet good install thread here...
https://*****************/forum/f20/easy-console-8-sub-upgrade-sound-ordnance-b-8pt-1457573/
https://www.crutchfield.com/p_777B8PTD/Sound-Ordnance-B-8PTD.html#&gid=1&pid=2
Anyway, my only problem seems to be that it is too high. Top top of amp hits the bottom of the cassette box inside the console. Seems to be about 3/8-1/2" too high for proper clearance. There is a few install threads on this unit but no one seems to comment on a height problem.
I did add a thin felt pad adhesive to the bottom but that is probably only 1/8" and def needed to keep from vibrating on the metal floor. Then it dawned on my that maybe this unit has slightly change in dimension from the older threads.
Can anyone confirm? At this point I may have to remove & mod the cassette box but hoping to take another look to see if I goofed something up.
