I bought this Jeep almost a year ago & it already had a Smittybuilt bumper, LED headlights and no fog lights. I found the wiring for the fog lights tucked up underneath the radiator & figured I'd pick up some LED flood lights from HF. I got them installed & realized the PO had removed the fuse for them. Come to find out the multi-function switch that controls the headlights, fog lights, turn signals & hazard lights was worn out to the point that the fog lights would randomly come on by themselves. So I picked up a new multi-function switch from O'Reilly's (lifetime warranty). I got it installed easy enough, including the swap of the old flasher, and now the headlights & new off road lights work fine. The weird thing is that now the turn signals & hazards don't work at all. I reinstalled the old multi-function switch & same thing. WTF, they worked 10 minutes ago fine?!
So I picked up a new flasher & still nothing. At that point I found a blown 20 amp fuse in the fusebox up by the battery called MF SW. I go get another 20 amp fuse, install it with the old multifunction switch, test that everything works fine (and the off-road lights come on randomly). I pull the fuse, remove the old multi-function switch (again), and install the new one. Then I reinstall the 20 amp fuse & test the hazard lights. Immediately the fuse pops. WTF?? Bad multifunction switch out of the box?
So I return everything to O'Reilly's, get a total refund & go to Autozone. They have the same multifunction switch in stock. I get it installed with a new MF SW 20 amp fuse. I test the hazards & YES! Success!
I begin testing every scenario of lights I can think of. Heads lights work, off-road lights work, brake lights work, parking lights, turn signals....... and then I notice the rear parking lights don't work when you just have the parking lights on. WTF? Another defective multifunction switch??
I'd hate to be doing this with Rock Auto or Amazon. Do I really have to go to the stealership for a quality product?
