I have a 1998 Wrangler TJ with the 2.5l engine in it. I’ve been thinking about building a 4.0 engine for it (won’t be 4.0 for long), but that’s a topic for another day. My problem right now is concerning my fourth fuel injector. I have been getting check engine codes since I bought the jeep, and honestly kind of just ignoring it (not wanting to get in to deep kinda thing) but I bought myself a obd2 scanner and found out my 4th fuel injector had an open circuit. So I replaced it no biggie, cleared the codes and went on my way, but the light case back on very quickly and so got to wondering. I took a look at several things in the engine bay, and looked at all the wiring and someone’s definitely messed with it before, and pretty poorly, there’s a jumper wire on injector 1 going to the actual plug where all the injectors go to I believe, but that’s not causing a problem, not right now atleast. So after I replaced the injector you could tell it was performing much better, but after a little driving it felt like it was dropping it occasionally, and idle seemed rougher. I don’t think the injector is bad, I’ve swapped it to another spot and it worked fine, and the other injector I put into #4 started dropping. I was wondering if I should check all the wiring, maybe even replace it all to get rid of that god awful jumper wire, or is there another problem tjs commonly have?
