Will it affect the turn radius?A wider wheelbase will give more stability. However, I wouldn’t worry about my TJ tipping over off-road. They can lean way, way over and be fine, even when lifted substantially.
When onroad I wouldn’t take corners fast. It’s a TJ and not made for fast cornering. Prior Jeep’s were known to tip over and that reputation persists, but our TJ’s don’t tip as easily. They are pretty stable vehicles.
Ultimately, widening the wheelbase with a smaller backspaced wheel, 3.75-4”, would only help add more stability. Plus, I think it looks better, up to a point.
Only by 1/2 of the additional inches you extend your tire including changes in backspacing, i.e. very minimally. You won't notice.Will it affect the turn radius?
So to widen the wheel base all I need is spacers?I think all of of have a wider wheel base than stock. I've got 12.5" wide tires, plus 1.25" wheel spacers, so much wider than stock. No disadvantages in my book, other than maybe you won't be able to fit in the same parking spots you did before.
Things like what? Also I’m not looking to lengthenIf I where to widen the width and lengthen the wheelbase, there would be things other than stability driving that decision.
