I didn't ask about the pitman. Is the track bar dropped in the front?no spitballing allowed hahah.
no drop pitman and no need to have it, steering is parallel with track and drop bracket is installed to maintain the front steering geometry
Whoops that's a problem. Replace it with the stock factory non-dropped. That will cause left/right darty steering as the front end travels up & down over bumps/dips in the road. If you're accelerating/decelerating hard enough to make the front-end go up & down that dropped Pitman arm will cause bump steer (the steering shifting left/right as the front end moves up/down).yes sorry it is dropped
If you have a dropped track bar amount at the frame you need to either do away with that or install a drop pitman arm which is just a redundant change of stock anglesthe track bar is dropped not the pitman
It looks like you have some sort of dropped frame side track bar mount. Do you also have a dropped Pitman arm?
That Fox stabilizer has been known to cause a push, you could try a quick drive with it out to see if the push remains.
After going through a pull/push scenario a couple months ago with mine, make sure the toe is set properly, and that the steering is perfectly centered. Mine had the steering wheel off center just a few degrees, and once centered the push/pull disappeared.
I can't tell because I'm not sure what the stock one should look like...I had CJs and FJ40s and Broncos, and a JK and LJ (stock LJ for the most part), but never a TJ. I could go check the LJ and see what that one looks like, but that could have been a drop pitman arm and I wouldn't know it either...my neighbor owns it now so at least it is close. I can hunt for web pics to find out.
I can't really tell from the pictures but it does look like you have a dropped track bar frame mount. If you do, you also need a dropped Pitman arm to keep the drag link and track bar parallel. Most people would say you are better off with neither but I can't say. The stock TJ is identical to the LJ.
