When you install the tummy tuck, you are pushing the trans up closer to the tub. Now with the exhaust hanger seated into the bracket on the side of the trans bracket, you are pushing the exhaust up higher. Look at exhaust after the rear cat and you will see it angled up. By shortening the mount you are allowing the exhaust to come back down into its normal position. I had to do it on both my TJ and LJ. The TJ wasn't as bad because I did have lifted motor mounts. If you don't correct it, it puts stress on the hanger that is back by the 3rd cat. The hanger will tear off and leave a gaping hole in the pipe. Ask me how I know.
I hope I explained that right.
This,I used heat and a pry bar to bend my hanger down,worked like a charm,before I did this my exhaust was rubbing on the passenger control arm mount.now I have lot of clearance
