So the time has come for me to return to commuting again. I was wondering if it is advisable to tape or cover the holes on the side of my frame just to prevent road salts from getting in there for the winter. I live in Central Jersey.
I have had the 4 holes by the front and rear control arms covered up since i got the car with plugs, but i was wondering if i should do the same with the holes on the side of the frame.
I also drilled a couple holes by the rear control arm mounts so there are multiple drain holes at the bottom of the frame.
The frame is soaked in fluid film and I use salt-away on prone areas whenever i see some build up.
