Hi Gents
I am going to install some 2 1/2" springs in place of a 1 7/8" spacer lift. If I have vibes and must lower the transmission, I will probably buy a kit for it. When this is lowered, does it require a motor mount loosening then retighten? What about the radiator shroud? Will it need adjustment ?
I have looked around for this info , but can't find it. Reckon it would come with the directions in a kit.
If no kit is available, how much should I shim with washers for the first try ?
This is for a 2000 SE 2.5L with standard 5 speed trans.
Thanks for any info
Pete/MS
Thanks for any info
Pete/MS
